Jewell, IA | No.......the Ez guide 500 and Ez guide 250 both contain internal receivers. You are only able to use the antennas that are offered with the systems. You can order a five hundred with an omni star antenna or a waas antenna. However, the internal workings of the 500 are the same so it is fully upgradable if a waas antenna is ordered. The 250 is strictly a wass lightbar. It comes with a patch antena for $1495, but can be upgraded to use the same waas antenna that is used on the ez guide 500. I hope this helps. | |
