South Australia | Tried setting one of these up this arvo for the neighbour.
Problems
Won't spray with the trimble hardi kit connected
Rate not responding comes up on ez-guide 500
High rate alarm on 5500 controller
the ez-boom has logged no faults on the 500.
Other questions. Should the ez-boom be set to inline servo and should the pressure sensor be turned off. Starting to wonder whether it should be set to something similar to what you would use on clutches. The trimble hardi manual is useless. No info in regards to settings.
Any help is appreciated.
Cheers
Waterbottle | |
