Posted 4/13/2008 23:25 (#357433 - in reply to #357161) Subject: RE: CNH Precision Air Cart & Pro600 Display
NE SD
I don't follow. You plugged the FC cart into the back of the tractor and had the GS2 on the other end, or plugged the cart in and had the FC monitor plugged in in the cab?
You might try unplugging the display, turning the key on and letting everything fire for 20-30 seconds, and then plug the display in.
