The Green Hills of Missouri | After two and a half hours last night I finally had that thing on the ground. Finding the balancing point was a chore in its self. Brand new NAPA 1200# trans jack had all it wanted to lift to remove pins.
So now its on the ground, how do you remove it from under the machine? If you let it rest on the floor the tunnel portion rests up under machine. Doesn't look like theres clearance on the RH side for the idler pulley shaft and drive pulley to clear the lift assist springs.
it was late last night when I finally got it down so I may have missed something.
Thanks for the help. |
