Search Forums | Classifieds (24) | Skins | Language
Haybuster 2620
jd720
Posted 10/6/2014 19:22 (#4112670 - in reply to #4112436)
Subject: RE: Haybuster 2620
South East SD
We've got the 2620 and it does a good job for bedding if your not looking to throw the material into a building or shelter. We also use it to put hay in bunks for starting calf's. The update kit is really simple to do its just some longer bolt and some 2×6 tubing. I was told they only made so many kits and when there gone there gone. They also have a pressure relief valve to put on the bale lift cylinder so that I you try to lift a froze down bale it doesn't bend the brackets. The deflector adjustment is kinda a joke so I torched it all off and put a cylinder on it like the newer ones have and that makes it a lot better machine. I can get you pics of the update kits and the modified deflector. But overall very happy with it and its been trouble free.
