roaming | You'll have to check with Outback to see how they transmit the data. You need the TX from the receiver to go into pin 2 on the display 9-pin connector. Whatever cabling you need to accomplish this... Whatever serial cable they supply will probably work. For example, the EZ-Guide Plus outputs in a null modem format, so Trimble supplies a null modem cable so that the signals are on the correct (standard) pins at the other end of the cable.
Also, remember that the display DE9 connector is not grounded, so you may need to provide a separate ground for the data ground wire from the receiver.
Edited by torn 4/7/2008 10:29
