Thumb of Mi. | I have not read that yet I will check it out. The harness that was in the package I order only had the capabilities of runnning 4 clutches or cylinoids. I think with the external switch box in the cab you can control more. The planter only had two clutches on it for half disconnects. Since then we have added a jack shafts and two more clutches to break the 24 rows up into 4 blocks of 6 rows to full utilize the wire harness that came with the rate controller/swathpro | |
