Northwest Iowa | I am using 'Clarity'. I do not know the inclusion rate without going to check the label. Your herbicide supplier should be able to help you find this product. Also, without checking the label, this may be a restricted use pesticide and may need to be a certified private applicator to purchase. Edited to add- I googled Clarity and I did not see a restricted use label, so you should be able to find and purchase this herbicide.
Edited by cowfeeder 6/23/2014 19:02
