| That plug should go into the outlet on the back of the Cruizer that is under the label on the back. The plug on the back needs to be hooked up to a source that turns on 12 volts when you turn on your master boom switch, so teeing into your foot switch should be the way to do it. You'll also need to go into the settup section of the cruizer and set your "switch" so it's switched away from "touch screen", but I can't remember the exact wording of the selection, there are only 2 though, so it should be the other one. This way it will stop painting the ground green, and it will also stop counting acres. | |
