Posted 2/22/2014 18:24 (#3709467 - in reply to #3708312) Subject: Re: I Guess I'll Be Putting The Snowblower Back On The Tractor Tomorrow (4 Pics)
Wisconsin
When I first saw the post caption I had the same thought as lucky why would you unhook it so early. I knew you had other thing's that you did with the tractor so I let it slide then. Eventually you may learn that if you leave it hooked up it won't be needed as much. Then you will be back to what is that blower doing on the tractor when I could be useing it for other thing's and your back to hooking it up in bad condition's.
