Posted 2/19/2008 23:14 (#314281 - in reply to #313878) Subject: Re: Variable Rate Seeding Options
Redfield, SD
a serial cable with possibly a nul modem and gender changer, but other than that you should be good to go. I personally would run the iPaq in a powered Ram Mount which gives you the serial connection you need if you are running a CF receiver.
