Sunnyvale, CA | The DJ PM3000 Planter monitor needs a radar gun and the EZ-Guide 500 outputs simulated radar pulses on the 9 pin connector. If you use either cable 52033 or 62749 (preferred - has a right angle 9-pin connector) with the EZ-Guide 500 the radar pulses are on a 3-pin weather pack connector on each of these cables. Use cable 54806 to connect to the 3-pin weather pack . This cable has a Dickey-john radar connector and plugs into the DJ monitor. The dealer who sold you the EZ-Guide 500 can get these cables for you. | |
