Posted 2/15/2008 15:11 (#310563 - in reply to #310452) Subject: Re: Trimble Insight with Outback Edrive
The Insight is not Trimble but rather Ag Leader, they are not tied together at all on that display. The Outback edrive will not work with the Insight either. You could use your outback to supply a GPS signal to the Insight if you wanted to use it for a yield moniter in your combine. Looks as though you may have only one option and that is to go with the S3 if you want a newer display than your S2.
