| Both the N1 and the N2 are plug and play with the EZ-Boom, just remove the Raven and run it inline.
If you only want the Boom switching you can buy the Tee peice from your local Trimble dealer there is no rewiring to do either of the two options and you will still be able to run your master on and off on the hydrostat lever though the boom switches on the hydrostat lever will have to stay off.
For individual control when you want one section shutdown in an area that hasn't been sprayed you will need to turn the corresponding switch off on EZ-Boom
Overall it is very easy
Cheers Burt | |
