Posted 11/10/2013 22:44 (#3437000 - in reply to #3436206) Subject: RE: 96 dodge cummins fuel bleed back?
ECMN
The most common problem I have seen with them is the fuel supply line
gets rusted and starts sucking air. .
You can put some clear fuel line between the fuel pump and the fuel
line on the frame rail and if you see air bubbles while running you know
your problem is between there and the tank.
