North west MN | Sounds good but just what are you getting? Receiver? Base Station? Autopilot? Autoswath? I use the Trimble RTK Base Station With autopilots and Insights I also use rtk for my EZ-Steers. When Harvesting I use the insight for yield recording. When Spraying the insight controls the tractor and the rate and shuts off the boom to avoid over application. Same when planting. Once you have the ab line set with the insight and rtk save it and you won't have to set another ab line again in that field. As for putting it in the combine you will like that too. | |
