northern Mt | Which software and hardware do you use for "POI" (Points of Interest)?
What typical "POI" do you mark?
How do you use the POI shp files to your advantage?
I use IPAC for hardware and EZ-Map for software on IPAC for logging.
Then ARC Explorer or Farmworks Site for planning application and history.
I typically mark cheatgrass areas when seeding (to spray out before crop emerges);
wild oats patches during broadleaf spraying (to spot spray later);,
and large or buried rocks (to remove later). | |
