red river valley se of fargo | I have a '98 roto-disk. It has hydraulic deck plates. One of them is broken so it won't adjust properly. I can't figure out how to remove it for repair. There is a pivot bracket for the adjustment arm on the front that I removed, the rear of the arm goes to a blind hole as near as I can tell. Can the plate be removed without removing the adjustment arm? Do you remove gathering chains and go from above?
p.s. dealer has never had to remove a deck plate! Weird! |
