Renville County, MN | I am not sure but I think if you don't run a data card it will beep and sqeak at you. Do your roll calibration on TCM and if you get autotrac to run go with it. Seems like a person had to always fiddle with it and there was no rhyme or reason on how to get one or the other going. If you plan on keeping combine and want to use autotrac a lot find a good used 2600 or 2630 as I think you will be much happier unless you like swearing and holloring at the brown box. | |
