Tuscola, IL | I assume the compressor isn't running? If its not, check for 12 volts at the compressor. There should be a 2 pin connector near the compressor. If no voltage there, check the voltage at the switch. You'll want to check both sides of the switch. If you have voltage at the compressor (with switch on) then check to make sure you have a good ground to the compressor. If all that checks out, i would guess the compressor will need to be replaced. You can also try jumping 12V to the compressor. That will tell you if it's good or not. | |
