Iowa | I used to feed it. I liked it; it was cheap and the cows really did well on 10lbs per day. It will freeze like almost to an ice cream consistency if it gets to cold.
Called the ethanol plant yesterday to see if I could get some. They said sure if you have a steel tank, I explained I haul in a 1000 gallon plastic poly tank and they would not sell to me. Said they turned the processing up on the syrup and it will melt plastic tanks. Said it gets over 200 degrees. | |
