Death comes to us all. Life's but a walking shadow | Jon,
What data did you use to determine the weekly burn rate numbers? Do you have the data available to extend the table for the whole coming next year? When you calculated carryout you used modified USDA numbers for Feed, FS&I, ethanol and export, correct? Is there a way to reconcile the burn rate numbers with USDA numbers as a check to see if they agree? |
