n.c.iowa | check opener disc diameter, seed firming point and seedboot.if it's got more than 8000 acres parallel bushings might need to be replaced.check all seed meter drives and chains and bearings for rough spots and wear.lubricate the chains.check press wheels and gauge wheels for loose bearings and cracked rubber.look at the singulators,check them for flat spots and broken mounts. |
