s.w. Wi. | I have a John deere 530 baler and while baling the oversized bale light kept coming on. The bales were still set at 5 x 5 so I started checking everything out and the only thing that was different was that the gate latch clearance on one side was about 1/2" bigger than it use to be. Does that mean the gate is twisted and if it is how do I straighten it. The clearance used to be about 1-2 mm on both sides.
I bale on a lot of hillsides and do have to dump bales there if that had anything to do with it.
TIA | |
