How many tons to the acre will 6-7 ft tall corn make that may make 75 bu if lucky.
paul2sd
Posted 8/19/2013 21:24 (#3276881 - in reply to #3275111)
Subject: Re: How many tons to the acre will 6-7 ft tall corn make that may make 75 bu if lucky.
go out in the field and cut off some representative stalks at the height you would normally chop it and weigh them on a good scale and calculate from there with your population. you'll lose a little from some fine leaves blowing away on windy day, but will be in the ballpark
Paul
