Posted 8/13/2013 20:03 (#3265801 - in reply to #3264853) Subject: Re: Bagging question
S.E. MN
That size bag will be about 12-14 acres. If you want to mix, your best option is probably to use two bags and blend as you feed out. Also as stated layering in the wagon will work. Feeding from both ends of bag can allow air to travel through, usually turns to junk!!
