Whiskey, Tango, Foxtrot | I've seen everything from almost full walls, to no walls at all. Most hay barns are roof only, here. I'd want at least one side full open for access. I have no idea how any of that would work in your climate. It is dry here, dry air and little rain.
But the cheapest storage is going taller. Min of 20' eaves here to make our stack pattern work, and most are 22' or better. Only cost to go taller is longer poles, and tin if you sheet the sides. | |
