| If it doesn't have a cv joint, it will probably make noise when turning, that is just the nature of a set of u-joints. The cv joint is supposed to smooth out pto speeds when turning. If it does have a cv joint, you need to put a lot of grease in it, every day. I would check u-joints, also because mine were getting worn and making more noise while turning right, and new ones made it a lot better. I also have a cv joint. | |
