| It depends on how many animals you are feeding.
It not only reduces feed waste, but it ferments better,stores better and usually will not take more HP because you can cut it a little longer when rolling it.
I started using a kp 17 years ago and believe it is a good investment when feeding dairy cows.
I am starting to see a few Pull types with KP available in WI because more people are going to a larger SP unit.
Find someone locally to chop some for you and test it yourself. | |
