Faunsdale, AL | Quick crete concrete mix won't stick........tried that before. You need some lime in your mix to make it stick to the wall. Quck-crete probably makes a patching mortar/stucco mix, but you can make some up yourself using mortar mix and adding some portland cement for durability/resistance to silage acid. Sealing with an epoxy would be best, but then when it flakes off, you have the difficulty of preparing the surface to patch again. With cement mortars, you just pressure wash and trowel or spray it on. | |
