Posted 7/2/2013 13:40 (#3187169 - in reply to #3186883) Subject: Re: Varifan Wiring Question
SW MN - mt. lake/windom
Check to see if there is a common breaker or overriding t-stat for 3,4,5. Should be a feed to controller and feeds to fans from breaker panel. Check power @ breaker and any other common connection when controller shows on. If all ok,then bad ciruit board in controller?
