Posted 6/17/2013 16:43 (#3159882 - in reply to #3159741) Subject: Re: Removing Stuck PTO pump
Nc Ks.
Have notice that if the splines in the pump are worn down, they will bind worse. Ditto on lubricating the splines before slipping the pump on, but you might want to check the splines in the pump for wear. Be careful on older machines. I've seen those things worn down to the point they are as sharp as a knife.
