mascoutah, IL | My cooler is not putting out any vapor. Used it six weeks ago and worked fine. Used again the other day and got way too much out of a tank ( reading vapor). Last time I had this problem the 1/8 inch barb on the back was plugged. Couldn't find an obstruction this time. Coop guy told me to blow air through that inlet, then plug one of the vapor outlets and see if I could get air out the other. Tried that and got air but don't know if I blew anything out in the process. Problem is I'm sidedressing the rest and need this thing to run without playing around for days. Anyway is there anything else I could look for or should I be good?
Edited by dmswil 5/21/2013 21:18
