Looking at a 4720 with 1800 hrs, how concerned should I be that the right frame tube is cracked halfway around the tube? The crack is where the rear axle is welded to the rectangle tube. Some welding has been done on the front end of the machine also.
Put the frame stiffener kit and hope for the best, or run?
