Posted 5/19/2013 07:43 (#3104872 - in reply to #3104641) Subject: Re: What is the proper way to hook hose return for vac on 8120?
NE Illinois
Your vac return should dump in sump so that if you bump scv or shut tractor engine off the vac motor will be spinning and and oil has no place to go, and it should have a flat face end on hose. This will reduce oil temp.
