Posted 5/21/2013 06:30 (#3108823 - in reply to #3104962) Subject: Re: Massey Ferguson 3545 Trans Input Shaft Seal
Somewhereville, Earth
blocked breather? or breather with too high crack off pressure? make a hyd hose from the trans housing up the back of the engine under the bonnet, somewhere safe, put a hyd breather on it, or take the seal to a hyd shop and see what options you have, you may find a higher pressure wider one that will fit, moving the wearing surface on the shaft too
