Posted 5/1/2013 15:30 (#3073884 - in reply to #3073539) Subject: RE: Sprayer is going on outside of boundaries
Hillsboro, AL
You have a small skip between your headland pass and the boundary. The Integra is turning the section back on to spray that skip. It is best to turn the master boom switch off when swing the the boom outside the boundary for this reason. I make it a habit to turn the master off after autoswath has shut off the sections. Then turn the master back on after you have completed your turn and are lined up to go.
