Search Forums | Classifieds (52) | Skins | Language
Deere 8410 Return & Case Drain for White 8824 Planter
michael3130
Posted 4/26/2013 19:46 (#3064812)
Subject: Deere 8410 Return & Case Drain for White 8824 Planter
Iowa
We bought a White 8824 planter which requires hydraulic remotes for the Singulation blowers / hydraulic drive and CFS Tank blower.
The CFS requires a case drain line so that the oil goes directly back into the reservoir. Our 8410 doesn't appear to have this. Do I need Deere part number RE222721 to do this correctly so there is zero pressure on the return line? I was told we could plug it into the dual motor return couplers we do have...is this correct?
Also am wondering if the right side of the remotes / couplers is the pressure and the left is for returns if you choose to go through the SCVs. (We won't use the SCVs for the CFS drain line, but wondering for all the other return lines)
Thanks in advance.
