Goodhue County MN | Does the max PSI rating of a hydraulic motor need to exceed or match the Max tractor hydraulic pressure? I have a JD 7520 and want to run a hydraulic motor on a auger with it, what does the tractor run for hydraulic pressure? Can I run a motor rated at 2050 max psi with the 7520? Can you adjust the pressure? I know you can adjust the flow but does that increase pressure as you decrease the flow?
So for all the questions, just want to get it right..... | |
