______- | is it a new or old frame on a new frame you would screw the drywall to the post and beam structure to temporarily hold it in the right place, than frame a stud wall place it up against the structure, screw the drywall to the studs from the inside, you would also have to do your plumbing wiring and insulation from the outside. essentially building inside out. They also make (sips) structurally insulated panels, to look after this problem. | |
