Posted 4/10/2013 22:42 (#3026573 - in reply to #3026540) Subject: Re: Air Compressor Valving?
Northeast CO
It would be part # 24 on the diagram, you will probably need to fix it to get it started/make it easy to pull. What brand is it? Your JD Dealer should be able to get the part you need for it, Bomgaars or something similar will have it also
