| Sounds like the power supply. I replace a lot of bad Dell PSU's. I use Antec power supplies as replacments and have a lot less problems. I think the PSU is one of the most overlooked item in a computer and poor power can lead to a lot of other problems........sometimes you just cant tell that is the problem. Systems that run hot, fail memory, fail hard drives...........etc often can be repaired with a new quality PSU.
Van | |
