| I hear you. I just don't think there will be a set of M series in the country that will be available unless they are pulled from our spare parts stock. There will be such a pronounced difference between the behavior of the 2 wheel designs you mentioned that it may not be necessary to have our latest wheel to compare and contrast the two systems. You will want to be careful to not use a totally worn out curvetine set. If the teeth are too narrkw they will not perform optimally. | |
