Posted 3/27/2013 12:43 (#2995465 - in reply to #2995336) Subject: Re: soybean seed size and vSets
You may have to make your own sprocket. Get a weld-on sprocket and find a hex hub to weld it to or cut out the hex hub from a Kinze sprocket that you never use. You could replace that Kinze sprocket when ever you want.
