NEIN | I am doing my own corn spraying this year and will be using Lumax-ez. I would like to use the same nurse truck as the planter but how important would cleanout be when going from a 28% & 10-34-0 starter mix to plain water for spraying the Lumax & Atrazine mix ? The nurse tank is not fully sumped so I anticipate a few gallons of the starter mix could be left in the system when we add water to spray. I will not be making hot loads in this nurse truck if that matters. Will it be necessary to "rinse" the nurse truck? Thanks for any help! | |
