Posted 3/22/2013 20:23 (#2983940 - in reply to #2980446) Subject: RE: Fertilizer placement in milo?
SW Oklahoma
Cain is right.
In a 30 inch row you should keep the N+K2O to about 5-7 lbs/A. Theoretically, that 15 inch row should handle 10-14 lbs/A N+K2O. In that 50 lbs of 18-46-0, you will have 9 lbs/A N. The 20 lbs/A of 0-0-60 will give you 12 lbs/A K2O. Put them together will give you 21 lbs/A N+K2O, well over the 10-14.
