Northwest Ohio | Your plan will adress your extremely low phosphate issue. I don't think Avail is that great of a product & is worth the extra expense. I suggest spending that money on micros. Your zinc ppm is the lowest I have seen in a while. Manganese is very low too, as well as boron. Add Boron 10% to your broadcast 5-10#/Ac. Add at least 1 qt each of zinc & manganese to your 2"X2", more zinc if you can afford it. Trials in NW Ohio showed a 2:1 or better return for every quart of additional zinc added up to 1 gal. / acre! Corn loves zinc! If this is RR corn - all the more reason to spend $ on Zn & Mn, as RR chelates micros & interferrs with their uptake! You have great levels of potassium, don't mine them down to where it will hurt your pocket book, maybe consider some - partial removal? Good Luck!! | |
