Clark SD | Bruce, what i do is export to a spreadsheet,i use lotus 123, but i just tried excell and that works too.
To do that you load up your Box car then load the file you want to export.
Then up top of box car you see some icon`s there are three in a row,one has 123 the next one excel and the next one shows ???. Check on the one with the ???.
When the export screen comes up you have some options.
With the data seperator choose space.
There is a window that shows what data you want to show, in your case with two channels there will be four, if you want temp in F just check the F ones.
Then go up in right corner and click on the export button.
Then clear the box car window.
Load up a blank excel sheet.
Then go up to top and click on the open icon.
When you get that window go the bottum where it says type of file and select text.
Then go up and select the drive that the box car application is on, then go to the box car folder and double click on that.
Then click on the file that you exported,sometimes there is two files that are same if thats the case click on the one that has text in the name
Then a window comes up there is a option between delimited and fixed, chose delimited. Then click next.
In the next window choose space. Then click next.
When the next window come up click on finish.
Try that and see if that works, i will go back and see if left ant thing out. Feel free to ask more question. | |
