Hillsboro, AL | you have changed the url that that you are using to get to Agtalk. There are 2 that will work. Your history is saved under the url you are using, so if you use one and then change to the other, it will not show your history. You can reach the forums at http://talk.newagtalk.com. You can also use the direct url that is something like http://onlinehome................(and a bunch of other stuff that I can't remember). If you use one url and then change to the other, your read post will not show as a different color. I would suggest always using the talk.newagtalk.com address.
