North Central Kansas | There was a feeder built with panels on a slide with pins on the ends so you just moved pins and let the cows push the panels up to the hay but not past the pin. Controlled, self feeding. I am doing this on the same concept with out spending $10,000 for feeding equipment. It will be a couple months before I am using it but I'll take alot of pictures unless it's a failure then I probably won't talk about it. | |
